Alright I am like just a hair away from having everything I need for this project.
and I need to know if I am heading towards right direction/light or hell here lol. SO I humbly ask for the more experience people in this forum for help here identifying what I need or what some things are. I should be able to get his project started by 2 weeks. and I think my buddies want to work on this a sunrise to dawn for about 2-3 days or is that probably impossible?
(I got 65mm 3.5l tb with adapter, wottech sports upper, 8mm wires, zex plugs, wideband 02 & boost gauge, trans cooler, #42 fuel injector, tuned pcm(I should had bought a programmer but this will do), intercooler/wastegate/bov/garret 60 turbo, older style timing chain set, 180 t stat, bunch of 45 and 90 bend and new cat and new mufflers, gaskets set, egr delete so far)
I hope I ain't short of anything here other than the return and feed line connections. I am unsure what I need exactly, but I am planning to buy this GlowShift Oil adapter(18x1.5mm) for my feed lines to the turbo. but as for the return, I am stuck at something, I think I need this weld bung but there is this adapter piece that looks like this but isn't exactly like it connected to the return line and I do not know if this should be taken off or is there a separate weld bung I need to get. I wish I have a close up pic, but I think the bigger line is the return and the thinner line is the feed right?
here is pics from the guy(BoostED00GagT) I bought the turbo from and this was his set up from searching his forum:
![Click image for larger version
I do not know what those two gasket looking like things in between those manifolds are are yet cause I can't figure it out since it doesn't seem like it should go in between the manifold as the manifold is longer, I understand where most things go now, and I am putting this into a 2000 monte carlo, which might work out good because the battery is on the left side and i don't need a battery relocation. I hope this works without major relocation of anything (I HOPE
) Well Any suggestions are welcome. Thanks if u read everything lol.
![Sad](https://www.60degreev6.com/vb5/core/images/smilies/icon_sad.gif)
