I'm planning a 3.4/3400 project using an S10 platform.Wish I could devote all my time and money to it but like most I can't, so it's an on going process.Know you've seen it all before but I still like seeing what you guys are doing so thought I'd share. Garrett 60-1 60 trim / 70 ar stage 3 / .63
Some goodies I've been collecting for my project
Tags: None
That be one pretty rotary mufflerWhat did it run you?
Cool, had the same turbo last year on my 3400. Ran mid 12's in the 1/4 on 11 psi. .63 turbine is tight I found. .82 would be better suited I think, even for a truck build.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
Originally posted by Mars View PostCool, had the same turbo last year on my 3400. Ran mid 12's in the 1/4 on 11 psi. .63 turbine is tight I found. .82 would be better suited I think, even for a truck build.
I don't even think you'll need the divided.
You'll see the .63 will spool at half throttle going accross an intersection... (still very fun though) !!11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
