autometer air/fuel ratio
  • autometer air/fuel ratio
    i put air/fuel pod on my car ! the problem was there! the pod have 4 wire the first one connect to O2 sensor (OK) the next one connect to the headlight switch(OK) the next one is a ground wire (OK) the last one was the 12v wire....so i decide to connect it whit the 12v cd player....the problem was that my cd player dont run..and if i take out the air/fuel pod the cd player run!!! my question is were do you take your 12v for the air/fuel pod ????????
    The battery.
      yah !!!! of course but ..the air/fuel pod will stay on when the car dont run and discharged the battery.....i think to put it on the key switch wire ...but i dont know what color is this wire and were it is !
        Mine's been connected to the battery for over 2 years now and I have yet to dicharge the battery. The car even sits for several days at a time without being started.
          Mine's hookes to the red wire behind the radio too. Mine works fine. Check all your connections and especially the grounds
          To Many Mods To List, Check It Out At
          Joe\'s 95 GA GT
          3100 Best ET : 15.389 @ 90.48Mph
          3400 Best ET : TBD
          My Cardomain Site
            Mine is wired to the "hot when run" in the fuse box.
            1984 Indy Fiero 3.4L
            13.7 sec @ 98 mph
            *ALL THROTTLE AND NO BOTTLE*
              I got the red wire on the fuse box too ( ACC "AKA" hot in run). THen the ground on the engine ground.
