I drive a 2000 Chevy Monte Carlo 3400. I got my turbo kit in the mail today, but won't be put on for a while. Problem: I am a complete noob, so I wanna learn and research as much before putting anything on. So now I'm starting with gauges. I've had many different recommendations from several kind enthusiasts around for our cars.
As far as I'm concerned the must gauge is the boost gauge, which in my case I got a Autometer brand boost/vac gauge, but still need to buy a boost sensor I think, if not on my turbo, I didn't get much of a chance to inspect it yet, that is where the sensor would be right? But for the vac part, does it read from the boost sensor too? since I don't see how you read both parts of the gauge.
So here is the recommendations I got from others:
Oil Pressure
Transmission temperature
Exhaust gas temperature (EGT)
Air/Fuel ratio or Wideband o2, but unlikely they are mad expensive.
Right now I'm thinking of Transmission Temp and EGT gauge. I heard a/f gauges aren't that accurate using the o2 sensor or whatever. As for transmission gauge, What am I looking for? What is the normal operating temp for my transmission or EGT and what is considered hot? since they range from 100-320degrees for the transmission gauge 300-1300 degrees in the EGT gauge. Right now I got my eye on the two gauges, with sensors, but wanted more recommendations and help. Also where would I be plugging those sensors especially the transmission temp sending sensor? I think the EGT sensor would be in somewhere in the exhaust piping?
Oil Pressure
