I am going over a few options for turbo header design on my 3500 camaro.
Turbo is a GT4088 going on a cammed 3500V6.
Right now, hotside, I have a "3500 front" manifold on the drivers side and a 3400 front (log) manifold on the pass. side of the car. 2" crossover pipe to the turbo. I went with this due to ease of install and reliability of cast manifolds.
I want to re-do the hotside,
Here are my options :
1. Upgrade the pass side of the system to use another freer flowing 3500 front manifold. (would match the other side and have MUCH better flow than a log) Good reliability and should never leak nice and sturdy.
2. Make equal lenght headers for both sides.
3. Make shorty headers for both sides.
What I'm basically asking is : do the 3500 front manifolds flow enough as not to choke out my setup ??
And my other question is are equal lenght headers as good or that much better than shorties. (The shorties have a shorter path to the turbine, BUT at the cost of not being equal lenght.)
looks like MOST V6 - V8 turbo setups go for a shorty header and drop the whole equal lenght thing... (like they don't ever try to get them close... one primary is usually 3X longer that another one) Kinda like this, most dragsters are done this way I've noticed... :
Pictured here is the 3500 front mani just for reference...
you can see it does have a somewhat good flowing design... I just wonder if it would be THAT much better to upgrade to a 3-1 custom shorty header.... The cast. manifold will hold the heat in alot better than 14 gauge tubing as well...
discuss.
discuss.
