ok, being a sunday, with nothing to do, i got bored.... very bored. so i started making a list.... what i came up with was basically throwing in stock specs for various 60V6 motors into the squirrelperformance turbo calc and then going through EVERY turbo to see which ones came even close to being suitable at different boost levels...
now, my definition of "suitable" was this:
efficiency had to stay above ~60% at all times where the boost threshold was met. i was actually amazed at how many passed this, but that's why there are other req's as well...
i wanted a NICE margin between the calculated airflow and the surge threshold at any time there was boost. this knocked out quite a few.
then, at higher boost levels, i removed all of the turbos that at any time went beyond the highest speed shown on the charts to get rid of the turbos too small to make enough boost without spinning at ridiculous RPMs.
and this is what i have so far... at the moment, it's just the MPFI 2.8 gen 1 motors as installed in a F-body(fiero and FWD apps are probably close enough to use the same charts actually.... and the iron-headed 3.1MPFI as well, methinks), but i'm planning on working up through the generations as i have time.
now, for the disclaimer
THIS IS MEANT AS SUGGESTIONS ONLY!
meaning, each individual vehicle and application will likely need something a bit different, but this should give you a good idea of where to start. this is also assuming you have a more or less stock motor(SMALL cams or LIGHT porting won't change things too much), after that, all of this gets thrown out the window.
2.8 RWD Iron Head MPFI:
~5PSI ~175HP
GT2252
GT2560R
GT2854R
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571
GT3776
GT3782R
T04E-40
T04E-46
T04E-50
T04E-54
T04E-57
T04E-57 DBB
T04E-60
T04E-60 DBB
T04B S-3
T04B V-1
T3 60
T3 Super 60
TB0348 86-87 GN TURBO
TS04
TD04H-15G
TD04H-16T
TD04H-18T
TD04H-19T
TD05-14B
TD05-14G
TD05HR-16G L
TD05H-16G S
TD05H-18G
TD06-16G
TD06-17C SY/TY TURBO
TD06H-20G
BRL4219E
K04-2275
K16-2467
K26-1
K26-2
K27
K14-2464
K24-2470R
K26-2664G
RS2-2672
53150-143
66130-178
66130-200
66130-224
~10PSI ~223HP
GT2056
GT2252
GT2259
GT2554R
GT2560R
GT2854R
GT2860R-1
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571
GT3776
TO4E-40
TO4E-46
TO4E-50
TO4E-SUPER 50
TO4E-54
TO4E-57
TO4E-57 DBB
TO4E-60
TO4E-60 DBB
T04B S-3
T04B V-1
T3 50
T3 60
T3 SUPER 60
TB0348
TD04H-13T
TD04H-15G
TD04H-16T
TD04H-18T
TD04H-19T
TD05-14B
TD05-14G
TD05HR-16G L
TD05H-16G S
TD05H-18G
TD06-16G
TD06-17C
TD06H-20G
TE04H-13C11
HX30
HX35
BRL4219E
S200
S2B
K04-2075
K04-2275
K16-2467
K26-1
K26-2
K27
K14-2464
K24-2470R
K26-2664G
RS2-2672
S256
53130-143
66130-178
66130-200
66130-224
~15PSI ~271HP
GT2056
GT2252
GT2259
GT2554R
GT2560R
GT2854R
GT2860R-1
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571R
GT3776
T04E-40
T04E-46
T04E-50
T04E-56
T04E-50
T04E-SUPER 50
T04E-57
T04B S-1
T3-60
T3-SUPER 60
TB0348
TD04H-13T
TD04H-15G
TD04H-16T
TD04H-18T
TD04H-19T
TD05-14B
TD05-14G
TD05HR-16G L
TD05H-16G S
TD05H-18G
TD06-16G
TD06-17C
TD06H-20G
HX35
S200
S2B
K04-2275
K16-2467
K26-1
K26-2
K27
K24-2470R
K26-2664G
RS2-2672
S256
66130-178
66130-200
66130-224
~20PSI ~318HP
GT2560R
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571
GT3776
T04E-40
T04E-46
T04E-50
T04E-SUPER 50
T3 60
T3 SUPER 60
TB0348
TD04H-18T
TD04H-19T
TD05HR-16G L
TD05H-16G
TD05H-18G
TD06-16G
TD06-17C
HX35
S200
S2B
K26-1
K26-2
K27
K24-2470R
RS2-2672
S256
66130-178
66130-200
66130-224
~5PSI ~175HP
GT2252
GT2560R
GT2854R
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571
GT3776
GT3782R
T04E-40
T04E-46
T04E-50
T04E-54
T04E-57
T04E-57 DBB
T04E-60
T04E-60 DBB
T04B S-3
T04B V-1
T3 60
T3 Super 60
TS04
TD04H-15G
TD04H-16T
TD04H-18T
TD04H-19T
TD05-14B
TD05-14G
TD05HR-16G L
TD05H-16G S
TD05H-18G
TD06-16G
TD06H-20G
BRL4219E
K04-2275
K16-2467
K26-1
K26-2
K27
K14-2464
K24-2470R
K26-2664G
RS2-2672
53150-143
66130-178
66130-200
66130-224
~10PSI ~223HP
GT2056
GT2252
GT2259
GT2554R
GT2560R
GT2854R
GT2860R-1
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571
GT3776
TO4E-40
TO4E-46
TO4E-50
TO4E-SUPER 50
TO4E-54
TO4E-57
TO4E-57 DBB
TO4E-60
TO4E-60 DBB
T04B S-3
T04B V-1
T3 50
T3 60
T3 SUPER 60
TB0348
TD04H-13T
TD04H-15G
TD04H-16T
TD04H-18T
TD04H-19T
TD05-14B
TD05-14G
TD05HR-16G L
TD05H-16G S
TD05H-18G
TD06-16G
TD06-17C
TD06H-20G
TE04H-13C11
HX30
HX35
BRL4219E
S200
S2B
K04-2075
K04-2275
K16-2467
K26-1
K26-2
K27
K14-2464
K24-2470R
K26-2664G
RS2-2672
S256
53130-143
66130-178
66130-200
66130-224
~15PSI ~271HP
GT2056
GT2252
GT2259
GT2554R
GT2560R
GT2854R
GT2860R-1
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571R
GT3776
T04E-40
T04E-46
T04E-50
T04E-56
T04E-50
T04E-SUPER 50
T04E-57
T04B S-1
T3-60
T3-SUPER 60
TB0348
TD04H-13T
TD04H-15G
TD04H-16T
TD04H-18T
TD04H-19T
TD05-14B
TD05-14G
TD05HR-16G L
TD05H-16G S
TD05H-18G
TD06-16G
TD06-17C
TD06H-20G
HX35
S200
S2B
K04-2275
K16-2467
K26-1
K26-2
K27
K24-2470R
K26-2664G
RS2-2672
S256
66130-178
66130-200
66130-224
~20PSI ~318HP
GT2560R
GT2860R-2
GT2860RS
GT2871R-1
GT2871R-2
GT2871R-3
GT2876R
GT3071R
GT3076R
GT3267-1
GT3267-2
GT3271
GT3571
GT3776
T04E-40
T04E-46
T04E-50
T04E-SUPER 50
T3 60
T3 SUPER 60
TB0348
TD04H-18T
TD04H-19T
TD05HR-16G L
TD05H-16G
TD05H-18G
TD06-16G
TD06-17C
HX35
S200
S2B
K26-1
K26-2
K27
K24-2470R
RS2-2672
S256
66130-178
66130-200
66130-224
