AiRrsearch t3 turbo on a 3100
  • #31
    Originally posted by gmmalibu View Post
    ok my fiero is an 85 2.8L v6, air intake, msd 6A series multiple spark discharge, msd blaster coil, accell 8mm spark plug wires, it smokes a bit, but here is my problem, drove a few days ago and drove fine, try to start and nothing, will crank but not turn on, looked around and found two plug wires in hoeeible condition one was burned and the other had melted through down to the bare wire, wires were stock , then replaced for super stock 8mm wires, car will not start, please help i dont know where else to look, replaced the ignition coil and still no start, checked the msd box and works fine, checked coil and its fine, car will not start at all, where else can i look or replace to get it running help.
    Plug wires don't usually melt through like that unless there is an exhaust leak breathing on them, you may have had a small fire and didn't see it if the damaged wires are on the front side of the engine. Did you check for a visible blue spark and if that was okay are you sure you have sufficient fuel pressure? One quick way to find out if the timing and ignition is in good shape is to spray a little starter fluid in the throttlebody, if it runs briefly you will obviously have a fuel delivery problem.
    • #32
      the car has no spark i checked the front and there fine the back two of the three wires were burned through down to the bare wire, distributor cap is good, ignition coil is good, plug wires is new, ignition rotor is good, msd 6a box is good, spark plugs is good, fuel pump is good, i havent checked the pick up coil... anything else electronic that could be causing no spark
