It occurred to me recently that some of you may enjoy seeing my build, and I might get some good information from posting this here too.
The build thread is on Pennock's Fiero Forum, but I'll give a (semi) brief description here as well.
It's an '88 Fiero GT 5-speed with a TGP shortblock and a late Gen III top end being pushed by a Borg/Warner S258 with a .82 A/R T3 exhaust housing machined to fit, all controlled by a '730 ECU. I'm guessing it'll make somewhere around 350whp on ~12 psi, maybe a bit more.
Later on, after I get the tune and setup dialed in pretty well, I'm going to build up a stout "3200" destroker shortblock using a 3500 block and a 2.8 crank with Diamond pistons (.100 over 3400 pistons) and 5.85" forged SBC rods, and I'll probably have the top end ported and a decent matching cam installed. Along with the huge W/A IC setup that I'm building for it and serious fuel delivery and (Clutchnet) clutch upgrades, the setup should support about 600whp on high boost and race gas, with a smooth enough torque delivery that the Getrag 282 might handle it (if not, I'll upgrade to the F23 I believe it is?).
The suspension is also being worked over. It's already all rebuilt, and I'm working out the proper way to lower it without screwing up the geometry, which is an easy thing to do with the '88s (screw up the geometry, that is). There are ways... The wheel bearings will also be seriously upgraded, as will the wheel/tire combo.
I'm doing some body mods also, and will have a custom high-quality paint job.
I recently had to sell my twin-turbo IROC-Z
to get a reliable daily driver, my 2010 Camaro V6 (3.6 DOHC VVT DI, 312hp) and I'm selling my 11-second AWD Talon and my stock AWD Talon, so the Fiero is going to be my only real sportscar to play with.
Because of that, I'm aiming for near ZR1 performance levels... Well, other than top-speed, reliability, ride quality and refinement. I'll save about $80,000 so that's okay with me.
Let me know what you think. If there's any questions I'll try to answer them, but most of it is covered in the build thread.
