What's the most boost a 60/6 has been known to take? If it makes any difference, I'm specifically curious as to how much a gen 1 block can take, and how much aluminum 3400 heads and manifolds can take, I don't care about any of the other stuff as everything else can be beefed up, just need to know for the things that can't be made to be stronger. Also curious how much the aluminum block can take if anyone knows...
Maximum boost?
The aluminum bowtie block? Who knows those are usually too expensive for us.
A gen3 block with roller cam would be a better place to start with. It has cross bolted mains and a structural oil pan. But Mars runs up to like 15psi on a stock 3400, with stock head gaskets. You can always go with MLS, o-ring the heads, whatever. I don't think anyone has found the limit of the heads yet... For high boost start with forged pistons, then forged SBC machined rods, then if you blow head gaskets, address that, and after that who knows what's the next weak link....
Being RWD you have access to strong transmission/drive line parts... So that part at least should be fine.sigpicNew 2010 project (click image)
Originally posted by 2.8/3400 1985 Camaro View Postand a 3x00 is out of the question as the application is RWD.
think the heads, manifolds and gen 1 block can take 32 psi of boost?
and there are RWD 3x00s out there...
john has a hybrid, and dave and brad are using full FWD blocks IIRC for their ponycars...
Yes, I'm aware its been done, that doesn't mean I have the desire or resources to do it myself...as for why 2 extra atmospheres, to wring every bit of hp possible out of a relatively small engine. Chances are I wouldn't run it that high most of the time, but I would like to be able to run with something like say a corvette if the occasion arised.
LMAO... You don't need 32lbs of boost to hang with a vette.....
Look at Loner666'... he had a FWD corsica, with a 3400 with 3500 top end, cam, and turbo running something like 9 or 12psi and was in the low 12's in the 1/4 with a slipping trans and probably no traction (fwd).
You will have less displacement, yes, but with 3400 heads and boost you will be golden. Port the heads correctly and you'll see even more gains, same for a cam. Go with 3" downpipe (merged). Or larger. Anything after the turbo is a restriction. (the same is not true for N/A, as yo don't want too big of pipe or you loose velocity and momentum of the gases).
And 32lbs means race fuel..... Or such a low compression ratio that it will be a turd until you spool up which means probably very high RPMs before it starts moving...
If you went with a camaro 3.4 block, 3400 pistons and heads (or even forged pistons) with boost and a stock bottom end and 2004 GM graphite head gaskets you'd be in the 12's with a basically stock motor and running under 2 bar of boost (9-12psi). Add a cam and that will only help.
What trans you running?Last edited by IsaacHayes; 03-18-2010, 01:12 PM.sigpicNew 2010 project (click image)
want to hear something that will BLOW your mind?
you can make more power on 5PSI with great heads/intakes/exhaust than a set of shitty heads(take 3800s for example) with 20PSI. all other factors remaining the same(compression/quench/etc), if heads can't flow for shit, they are a restriction.
restriction causes pressure if there is flow.
pressure causes friction, which causes heat, which drops power...
what you should be looking at is how much air(in CFM assuming a constant density) is needed to create your power goal.
At 8000 RPMs(redline) and a displacement of 173 CI it will need 440 CFM if memory serves. Not really sure why you mention the heads either...3400s on a 2.8, 3.1 if i stroke it is plenty, especially since once I reach the turbocharging phase they will be fully race ported, along with the manifolds and a 65 or 68mm throttlebody to boot. My knowledge on boost is somewhat limited, but I know what can bottleneck an engine and the impact it can have...Last edited by 2.8/3400 1985 Camaro; 03-18-2010, 01:31 PM.
358hp has been dynoed to the wheels using a manual and 9psi on a ported but other wise stock 3400...sigpicNew 2010 project (click image)
Originally posted by robertisaar View Posti'm seeing ~44PSI and 1050CFM on a 2.8 with 3400 heads...-60v6's 2nd Jon M.
