1996 Grand Prix SE hybrid/3100v6 Turbo T04E .50 trim 5-8psig
The title pretty much says it.
I know there is a delay of sorts that is increased the longer the vacuum lines are from the compressor to the boost controller to the wastegate actuator.
But, when running low boost, 5-8 psig, how bad is the delay if I keet the vacuum lines to a minimum distance from the engine bay to the cab and back?
Or in other words...Has anyone installed a manual boost controller in the cab? And if so, was it effective or should I completely avoid the idea and keep the controller in the engine bay?
Thanks guys
Thanks guys
