Was wondering what kind of max exhaust temps I will be encountering. Assuming the tune is good.
Stock 3100 with T04E .50 trim Turbo. Running anywhere between 5 and 8 psig boost. Stock exhaust manifolds, stock cross-over with 9 gauge (0.1875") steel where the cross-over merges the gases and where the wastegate taps in. I will also be using heat wrap across all exhaust to the downpipe near the cat converter (test cat).
Along with that question, what is the thickness (gauge or inch is fine) for the stock exhaust manifolds and cross-over?
I was meaning to measure but forgot while building.
Thanks guys, I would like an EGT Gauge but didn't want to spring the cost for one. Didn't think it was needed at low boost levels 5-8psig.
