I know this question has been asked a million times. I searched but couldn't find any solid opinions regarding the 3100v6.
I have been leaning towards a GT2860 or T3 TO4B, E?
The Compressor Map for the GT2860 lines up really well, if I did it right. This is what I came up with.
RPM EFFICIENCY
1.5k 68%
2.5k 69%
3.5k 75%
4.5k 79%
5.5k 75%
6.5k 70%
The two peak islands run rpm 3700~5200 (76%-79%-76%)
4500 being the absolute peak in efficiency. Not bad range for a daily driver urban street car.
I formulated very detailed instructions using the following formulas
CFM = RPM x CID x VE x 0.5
.................1728
n(lbs/min) = (boost psi + 14.7) x CFM x 29
........................(10.73 x ( X*F + 460))
Temp Out = Tin + Tin x [-1 + (Pout/Pin)^0.263]
........................Intercooler Efficiency
Tin = 90 deg F + 460
Pin = -0.5 psig + 14.7
Pout = boost psi + 14.7
Pin/Pout = Compression Ratio
Corrected Flow = lbs/min x (tin/545)^0.5
....................... (Pin/Psia)
Can you guys share your experiences with what turbos work well for a 3100/3400 v6?
I'm pretty sure about the GT2860 but just want to be sure,
Thanks
EDIT: What about a T3/T4 with .60 a/r compressor and .63 a/r turbine? Will that be a fast spool, mid range boosting turbo w/o hitting surge or choking the high end at 6k rpm?
I would do this myself with the math and compressor maps but the maps are hard to find. Especially when one is looking for a specific compressor map.
RPM EFFICIENCY
1.5k 68%
2.5k 69%
3.5k 75%
4.5k 79%
5.5k 75%
6.5k 70%
Thanks
