I am going to install an oil cooler for the turbo set up. I have the oil sandwich w/ feed and return ports. However, I know the trubo oil return needs a gravity feed.
BUT, I thought of this and I hope it will work. Getting an Oil Scavenging Pump designed for hot oil. It would work just like a low mount turbo but I have a question regarding oil pump placement.
Oil Sandwich > Turbo In/out > Scavenge Pump > Oil Cooler > Oil Sandwich
OR
Oil Sandwich > Turbo In/out > Oil Cooler > Scavenge Pump > Oil Sandwich
The idea is to run the spent Turbo Oil through an oil cooler before reintroducing it to the system.
I don't think oil gravity return will work at all with an oil cooler in the mix.
Any advice? Other then tapping the oil pan.
EDIT:
I decided to scrap the idea and went with a JEGS No-Weld, 4-bolt Oil Return Fitting. I know a non-weld fitting tends to leak after a little while but this item seems well built. With the right gaskets I bet I could easily punch and bolt a leak free oil return fitting with no welding.
The welding issue is I have an aluminum oil pan. I would need to buy a welder gun designed for aluminum welding (cost is too high for a DIY'er) or pay a welder to do it for me. This bolt on fitting is the cheapest, yet reliable method.
Non-Weld Fitting Link
All I would need is a -10 AN Male to 3/8" NPT Male Adapter to connect my -10 AN female Steel braided hose.
But if anyone knows the best place for a return oil pump, before or after the cooler, or other. Let me know please.
Thanks
OR
EDIT:
Thanks
