For street only and 8 psi you should lean towards the .82 housing since it is a T3 turbine as opposed to a T4. That should keep your exhaust back pressure at a reasonable level over the full range of boost. The old Ford turbo cars used a .63 on their four cylinder cars and I've experienced some what of a wall like resistance with a .63 on an iron head 3100 which didn't flow nearly as well as the 3500 so you will probably be much better off with the larger turbine which isn't large at all compared to your engine choice.
If on the other hand you will be limiting your revs to the low to mid 5k range the .63 should be fine. I went well above that sometimes seemingly trying to shake the piston off the end of the rod. I nearly did I discovered after tearing the engine down.
