I'm already going to deal with lag if I run that much pipin its going to add a bit more. Look at acura nsx's and toyota mr2s running a rear mount with a diffuser catches plenty of air to cool also remember I have an alky injection setup for it as well
turboing 86 fiero gt
Originally posted by kikinz24 View PostI'm already going to deal with lag if I run that much pipin its going to add a bit more. Look at acura nsx's and toyota mr2s running a rear mount with a diffuser catches plenty of air to cool also remember I have an alky injection setup for it as well
I didn't notice any increased lag with my front mount intercooler and I made it a point to do the math before conducting the experiment, I believe my results are in my build thread but the time to throttle body increase was such a small amount compared to what I stood to gain it was not a problem. My inlet air temps are now about 100 deg farenheit at ~8 psi on mid grade fuel down from 212 deg without an IC, that's good for about a 10% increase in power.
I'm going to convert it to rear IC because I don't have room for the proper pipe diameter to run the intended 15 psi over that distance and because I want to simplify the entire system for dependability, so I'll be moving away from the twin turbo setup also to a T72 or T76 single turbo with a .96 or more if necessary turbine housing. I also have a water/meth kit that hasn't been installed yet as well as 60 lb/hr injectors which is another area I forgot to mention to you may be a problem on a 2.8L if you can't pulse them low enough to avoid flooding the motor at idle since they are more than 3 times the flow ability of the stock injectors.
Although you mentioned other engines using the setup or similar to your plans, I believe all of them were more powerful and efficient than the 2.8L which means you are more likely to have too much supply for your engines demand which can be a problem.
Here is my car now with the front mount intercooler and cripplingly advanced camshaft that is likely cutting output by as much as 100 hp if CNCguy's estimate of 20 deg advance and my Dyno simulators estimate is correct. I'm going to degree it in to fix that.
Hope you succeed at what you have planned.
Proof of the front mount intercooler
I am running a 7730 ecm which from talking to a few people on v6z24 and fiero forums that comp can be chiiped propperly to change my fuel maps to run such large injectors. And if I'm wrong then someone tell me now buecause I will spend the time upgrading to a obd2 setup and using my hptuners. If I fail in the end ill know why. And then I will sell my turbo and get a smaller one its all about trial and error. This isn't a car I will ever drive but a few nice days s year and to car shows around town so Its a learning experience. I kno of guys who ran the tgp setups on z24 s with a larger turbo obviously not as large as mine but pushing amazing numbers. To me it is just a hobby, just like twin charging a sunfire it is absolutly under powered compared to just a turbo but the guy did it just to do it. It runs 13s but is a 1 of a kind. I'm pretty confident I can get this thing up n running propperly.
the turbo is entirly too big... I understand you got a great deal... but sell it and buy a T3/T4 and pocket the rest of the $$$$... i don't care how much you port the heads, bore the engine, and rev the piss out of it you will not make boost untill near redline... if its a show car thats fine..... (well that would be kinda gay actuall) but if you actuall want someting driveable this turbo is not it... I don't care what the magazines and articalls all say i know from 1st hand experience that turbo will be very dissappointing on that engine!
Hell my 3.4L DOHC 24V engine barly spools a standard T4 in time to make it much fun... if anything its a little to big, should have went with a T3/T4 hybrid, letalone on a iron head 2.8 MPFI with a fraction of flow from out of the heads. The TGP ran a Large T25 and it spooled about perfect on that old boat anchor 3.1MPFI...Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
I'm using a 3.1 for the car not the 2.8 that's in it. anyhow it is overkill and want to see if I can push it. Wats it guna hurt to try it if it don't work how I like I can sell it and go smaller with no problem. I originally bought the turbo oh hell about 5 months before I even found the fiero at the time I was going to turbo my grand cherokee 5.2 but the deal on the fiero came qwick so I bought it. And figured wth let's try it.
Originally posted by kikinz24 View PostI am running a 7730 ecm which from talking to a few people on v6z24 and fiero forums that comp can be chiiped propperly to change my fuel maps to run such large injectors. And if I'm wrong then someone tell me now buecause I will spend the time upgrading to a obd2 setup and using my hptuners. If I fail in the end ill know why. And then I will sell my turbo and get a smaller one its all about trial and error. This isn't a car I will ever drive but a few nice days s year and to car shows around town so Its a learning experience. I kno of guys who ran the tgp setups on z24 s with a larger turbo obviously not as large as mine but pushing amazing numbers. To me it is just a hobby, just like twin charging a sunfire it is absolutly under powered compared to just a turbo but the guy did it just to do it. It runs 13s but is a 1 of a kind. I'm pretty confident I can get this thing up n running propperly.
I have never heard of more than 300 + hp being produced by a built 2.8L or 3.1 and given that Ford 302 small blocks crack at around 500 hp I don't expect to. Again not trying to discourage you, just drawing on experience and observation to help you avoid wasting good time, money and effort.
I know we keep refering to your planned engine as a 2.8L but 3.1L is not that much more as the Fiero guys are already finding out from the wall they are slamming into when they put the Fiero intake manifold on a Camaro 3.4L and choke it down from its stock 180 hp.
This is the last thing I'll mention about the turbo you have, think about the movie Driving Miss Daisy, except instead of Miss Daisy you're driving a turbo around town in the back seat :-).
Yes I completly understand the injectors I've already taken this into consideration. And yes there is a 412 hp camaro with a 2.8 in it on the f body forums running a turbo that is honestly just shy of what I have fuel pressure will be lower and idle is set at 1k instead of 800 to kinda keep it up a bit. I understand ur not tryin to discourage me but I have the stuff at hand sitting in my basement so y not. If in fact I build it and need to downgrade turbo I will until then I'm goin for it. I considered swapping engine to a 3800 bc I've built a grand prix already and know how they run but that's about what everyone else does to these cars
Originally posted by kikinz24 View PostI considered swapping engine to a 3800
Originally posted by kikinz24 View PostIf I fail in the end ill know why.-60v6's 2nd Jon M.
I've done a ton of research in the past I know what I'm lookin to get and only way to do so is try it. Guys can bash all they want on how stupid I am for even wasting my time but I relle don't care because it all comes down to personal opinion. No offense but I wouldn't waste my time on a lumina to me its just a car. But that's my opinion. And obviously you feel differently about it. I was just originally posting to ask the simple question of should I brace my crossover. And this is what it turned into
YES, brace your turbo anywhere and any how you can... you have the T6 in hand, you see how big it is.. it will crack your welds with the heat....
i also understand you have what you have and want to make it work.... again my point is you can sell the T6 and have money left over on a turbo that will actually spool. find a compressor map for that turbo and plot your motor, it will be way off of the charts for what your motor will be capable of... I am one that understands doing something just for something to do as a hobby or what not... at the same time if it doesnt make sence it doesnt make sence... i applaud you for doing the project but just wanted to make sure you know what you should expect... what you do from there is your choice. Not bashing you but i am definatly discouraging you from doing something that doesnt make a damn bit of sence... (but doesn't effect me either way, just sharing my $.02 of turbo knowledge) map it out on the compressor map and show us how it will work.... that should end the conversation....
Compressor map should look simmilar to this:
SLast edited by RedZMonte; 09-10-2009, 01:36 PM.Shane "RedZMonte"
