adding supercharger
  • #16
    go on ebay type in grand prix tie rods and you can buy a whole kit of inners outers sway bar link bushings for like 70 bux shipped alot cheaper than the parts store.
    • #17
      thats because its ebay...i sure as HELL wouldnt trust my steering to some cheapass ebay part made by half a dozen 10 year olds in the poorest-shittiest most rat-infested district of bangkok known to man.
      • #18
        Originally posted by kikinz24 View Post
        the ss m90 is a little bit of fab work but works amazing! a stock 4.2 pulley will push about the same power on a n/a motor as a 3.3 pulley on a s/c motor.
        so ur sayin a smaller pully on a motor made for boost will make the same power as a motor not made for boost, with a supercharger on it, and a bigger pully? amd i reading this right or did i take too much bong?
        • #19
          since the blown 3.8s have a slightly lower compression ratio, yes.
          • #20
            wouldnt that burn the piston rings out? isnt there a reason a boosted motor has lower compression? everyone i know whos boosted a motor that shouldnt have boost as swapped the pistons, or stacked head gaskets.
            • #21
              depending on the difference in the CR and amount of boost, lower compression isn't always necessary.
              i think the CR difference in the boatanchors is less than .5... something 1psi could probably overcome. and they probably use the same rings for S/C and N/A setups.
              • #22
                from what ive read there is a BIG difference in strength between the 3.8 & 3.8sc bottomends, & im betting the pistons will need to be forged or at the very least aftermarket hypereutectic.
                trust me its not worth it considering people sell GTP supercharged motors for $400-$600 all the time (probably due to them no longer being needed to keep their boats in the same spot on a lake/river/ocean).
                • #23
                  here's a question that just dawned on me:
                  why are we still talking about the god-awful 3800?
                  THIS WHOLE THREAD HAS BEEN ABOUT A DAMN 3.8 AND STICKING A BLOWER ON IT.
                  how was this not locked on the first post?
                  have we gotten soft?
                  • #24
                    haha i was thinking the same thing but didnt want to be the dick.
                    you make a VERY valid point tho-im surprised ben hasnt bitchsmacked this thread yet LOL
                    my bad-i figured if i brought it to the top it would get locked so someone else doesnt bring back this failing frankenstein monster. i figured id just change my last post rather than adding a new one.
                    • #25
                      no_doz, you are the one that keeps bringing it back to life! It had been dead for almost a month, and then 2 days ago you posted in it again. Quit posting in it and it will die.... Geez!!
