sad news-the douchebag who promised me for sure that he would hold onto the rx7 convertible for me until saturday didnt & sold it 3 days after promising me hed hold onto it so now im saying screw it and getting a 87-91 camaro 5 speed & putting the lq1 in it since itll be decently cost effective & besides a motor mount everything should bolt up if i get a v6 camaro-id really like to find a convertible but i highly doubt that i will for any reasonable price
need gasket advice for boosting a 3.4 dohc
theres always someone who'll screw up your plans... but a LQ1/5speed camaro should be a fun car, probably pull somewhere in the 14 second range... but the only things i can think of that you'll have to deal with is the mounts, redrilling the starter, and i'm not sure of how much room is between the strut towers of the camaro compared to how wide the LQ1 is...
EDIT: the oilpan may also be an issue, in which case you'll need to modify a crossmember or fab up an oilpan.
Originally posted by robertisaar View Posttheres always someone who'll screw up your plans... but a LQ1/5speed camaro should be a fun car, probably pull somewhere in the 14 second range... but the only things i can think of that you'll have to deal with is the mounts, redrilling the starter, and i'm not sure of how much room is between the strut towers of the camaro compared to how wide the LQ1 is...
drops in. minor mods needed on the wiper motor and the heater box, stock mounts can be modified to bolt the lq1 in#1 1989 RS - THE L98 AND LT1/LS1 KILLER
1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
#2 95 granprix 3100 all stock for now
ported heads and cam comming soon, megasquirt ems and turbo down the road
also why would the 60* lq1 -possibly- have any problems fitting in a vehicle that came stock with an even larger 90* v8?
i hear that-the first time i popped the hood on my old 3.4 EuroSport (let's see how many of you guys have seen one of these lol-its basically an automatic 4 door version of the z34) i was in shock & was like "how the hell am i supposed to get to anything?!?! just a lot of intake manifold there :P
Originally posted by robertisaar View Postthat is one dirty motor... but its good to know its a relatively simple install. and no_doz has someone who can answer the questions i'm sure he'll have from someone who's done it....
im going to be putting an lq1 into a 1999 chevy prizm with a rwd conversion#1 1989 RS - THE L98 AND LT1/LS1 KILLER
lol gotta love that prism-why didnt you go full bore & just do it to a metro? lightest metro youll find weighs about, 1600lbs total- about half of what my lumina euro coop weighs, add 200lbs for engine-50lbs for the trans-150 for rearend & 200lbs for misc & you're as light as a stock crx with TONS more power
