lol thats pretty much what i had figured on but i figure id have them tilted 120* with short/straight runners that flow air directly to the ports since its being crammed in at all times by a supercharger-& has each charger flow to 4 cylinders, so basically itd kinda be like 2 eclipse engines, each with its own charger, hooked together, at the crank, not pos mitsubishi, with all of that dohc v8 goodness
also if i go this route (strong possibility since it takes badass to a new level & besides the degree of it being so custom, it wont cost more than going out & picking up an m112)-id setup an idler pulley with another attached to it, & route a seperate belt from the secondary pulley to the S/C's-that way i could go wtih a stock belt & taking it all off seems like itd be a lot easier this way.
