Ok here is my Problem
Last Summer the car ran Flawless, no studder, no miss, i could put boost to 7200rpm crisp and clean and bury the speedometer in no time.
Anyways i stored the car for the winter and just took it out last week, the car was fine in 1st and 2nd gear, but as soon as i got into 3rd WOT under boost, as soon as i hit 5000rpm it would studder and bog, then 6000rpm was fine till 7200rpm, and 4th gear was the same.
So i figured it was probably bad plugs.
the stock plugs are AC Delco R42LTSM and i put in Autolite AR94 plugs, so i figured id go a step colder and i just changed the plugs today using Autolite AR 93 plugs, set gap at .045"
well im guessing that the problem was definatly spark related, because now its way worse!!
it does it at 3000rpm now in 2nd gear and backfires and i cant even get to 5000 rpm.
is there a plug i should be using? gap i should set?
this obviously seems to be something with the spark plugs, but the wierd thing is, with the old plugs it was fine all last year, maybe its the colder weather, but i dont know.
i flipped on the wideband 02 today to see whats going on with these new plugs, its all normal , and when under boost it goes to about 11:1 afr until about 5-6 psi then it starts to chug and whatnot, it goes to 13-14:1 afr, i dunno whats going on, im hoping thats just the computer cutting fuel because of the chugging.
has anyone had this problem, any advice on plugs and gap, its 91 GTP with 3.4L DOHC personal experience is awesome for this kind of stuff!
Thanks in advance!!
Jake
Thanks in advance!!
Jake
