So either when my turbo dies or when i get my '94 Lumina running im going to a different turbo. The T04E super 60 will be out the door and the new Garrett GT3271 will be going in. I figure on 7-10psi will equate to roughly 400hp to the crank wich is about 60 more then im making now on the same boost level and also spool faster. it is a T3/T4 with a divided inlet (i believe they call it twin scroll). for $800 retail its a sweet turbo.
if i did my calculations correctly the corrected air flow is around "25.6" and the pressure ratio at WOT is around 22.9. after graphing it out it will be in optimal efficency nearly 100% of the powerband.
