I am going to start working on my turbo manifolds for my 3400 and im not exactly sure where to start for parts. Where would you suggest I get all of my tubing and flanges?
Help with turbo manifolds
Tags: None
are you building a "Log" style or a "tubular" style? Look on ebay for the flanges or have a machine shop make them. as for the manifold, Jegs, JCwhitney, Summit ect.. have prebent tubing if you make a tubular style. If your going with a Log style Vibrent performance has "Weld Bends" (T's, Elbows, Straight)..
I dunno if the 3x00 cars can do what i did but on the DOHC's the front stock log manifold bolts right up to the rear. if you can do that with the 3x00 manifold then go to a junkyard and for $10 you have a rear manifold. Then you just need a custom X-over and Downpipe and your set.
your log manifolds are going to be stronger and more reliable but tipically don't flow as good as a tubular... But you will have less problems with them. Again i have 2 stock logs on mine and make good power on the stock logs.
SShane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
here is one that someone built using parts from Vibrent Performance. this is a good setup.
SShane "RedZMonte"
Ok thanks I am actually going with the tubular style manifolds so I will check out summit and a few of those other sites for tubing.
And for flanges would these be good? http://www.milzymotorsports.com/miva...=3x00ExFlanges
I know they will work for my engine I just dont know if I would be better off getting my own made or just buying those.
Ok I have been searching those sites and I am finding alot of the parts I am looking for but I cant seem to find a 3 to 1 collector all they have are 4 to 1 so does anyone know where to find these?
EDIT: I found one does anyone have another place that has them?Last edited by Nick-G; 09-08-2008, 06:24 PM.
I can sell you some nicer flanges than that for a little more money, or ask betterthanyou if he is still making them, also better quality.
3 to collectors are available from S&S and Stan's headers.
If you are making them from schedule 40, you can get the 90*'s from McMaster-Carr.com, but I have used the 14 gage u bends from Stan's on a tubro kit and they are holding up nicely.
Wow, those Milzy ones are a terrible design! I'd like to see someone get to the spark plug easily with those installed. Geoff's (betterthanyou) are a much better design (because I did the design). They are the flanges you see in the post above, available in both O-port and D-port configs. And IIRC, he sells them for around $45 or so, so cheaper than Milzy's as well...
What would you suggest I use for gauge of pipe on the header pipes and my downpipe/exhaust?
Originally posted by Nick-G View PostWhat would you suggest I use for gauge of pipe on the header pipes and my downpipe/exhaust?
14ga or better at the minimum.
Here's my flanges...
Geoff's...
Are all of the collectors on stans headers 14ga? I know the tubing shows gauge but the collectors dont.
Also those are some nice flanges I will definatly consider those once I start buying these parts.
Another question on stans headers what exactly would be the diameter and radius of the u bend pipes? As in which is what? I know thats a stupid question but I dont want to mess this up because of stupidity on my part. lolLast edited by Nick-G; 09-08-2008, 10:30 PM.
For U/J-bends, measurements are as follows...
Diameter - overall diameter of pipe (ie, if you are doing 1.5" headers, look for 1.5" bends)
Gauge - match your other piping, ie 14 ga.
Radius - This is the radius of the bend, measured from the centerline of the tube. So, for a 1.5" diameter, 3" radius bend, your outer width of the bend with be 7.5", and your inner width will be 4.5"
Even better - I found a pictoral description - http://www.spdexhaust.com/J-bendsB.html#Last edited by bszopi; 09-08-2008, 11:19 PM.-Brad-
Here's a good source for u-bends. I've used them before and they are a dependable vendor. Their prices are very good also.
