here's a pic of the slots, filling these in apparently increases efficiency by letting less air flow back into the case.
Supercharged Propane 3.4
Hello I am new to the site. Thought I may get some info on turbocharging my 3.4 comaro. Anyhow I just read on an ebay add for a hydrogen generator that any modification done to burn a cleaner fuel is tax deductable. Don't really know how true it is because as I said I read it on an ebay add but figured it may be worth your while to check out. Looks like a sweet project.
yea, thats not something i would want to put in my car, to generate hydrogen (im asuming probly from water?) takes ALOT of electricity, would be a major strain on your alternator, not to mention, hydrogen, is not heat/flame friendly, the change of a leak (not sure how much it would be making?) and blowing my car to hell, isnt worth saving a few pennys...
might wana start a new thread about it, someone might have more/diffrent input on the subject, and not be reading this thread...
edit: and u might wana talk to forcedfirebird on the boosting a camaro, im sure he would have alot of input for you.
The other downside to running propane is that it has a hard time starting when the ambeint temp goes below freezing in winter. I've also heard it rots exhaust parts much more quickly but this was based on a co-worker's European econobox and might not mean anything.1995 Grand Am SE
Originally posted by hookdonspeed View Postyea, thats not something i would want to put in my car, to generate hydrogen (im asuming probly from water?) takes ALOT of electricity, would be a major strain on your alternator, not to mention, hydrogen, is not heat/flame friendly, the change of a leak (not sure how much it would be making?) and blowing my car to hell, isnt worth saving a few pennys...
A guy that comes in now and again for parts made a tank. With less than 5 gal of water and Liquid Drano he has had a flame going for about a month.
sphinksvt, I would be glad to answer any questions, you can start a thread in the boost section (or PM me) there's lots of well educated people here. Welcome to the community
Wow... why on earth would you not put a blow off valve on a boosted setup...
And now seeing the pipes on I understand how that all works... Before I was like WTF there is two air inlets... I though it was like a 3800 blower where the bottom is the outlet of the air, didnt realize it pulled the air in the back, and blew it out the top.
Well, The bypass valve on the back of the S.C. worked great when the throttle was upstream from the S.C. (draw through system) I've built a 'blow through' system and I thought the bypass would still work. But now I know, The S.C. is moving way to much air in this configuration.
Do you know of other S.C.ed setups for Blow off valves?Last edited by ssdurango; 06-25-2008, 11:55 AM.
Well yeah that makes sense, a draw through works totally different... your cutting off source, on a blow through as soon as you snap that throttle shut the motor is still spinning and it still has an air source but no where to go, so that boost has to go somewhere... and it found your slipperiest clamp LOL
Time to put a duck call blow off valve on it...
Originally posted by ssdurango View PostWell, The bypass valve on the back of the S.C. worked great when the throttle was upstream from the S.C. (draw through system) I've built a 'blow through' system and I thought the bypass would still work. But now I know, The S.C. is moving way to much air in this configuration.
It appears you have the BOV reference line hooked up wrong? The reference line need to be hooked up to the manifold after the TB. This way when the engine sees vacuum (throttle plate closed) the BOV should then open and allow the excess charge in the pipes escsape. In the video it looks like the more throttle you gave it, the more it would open.Last edited by ForcedFirebird; 06-27-2008, 09:03 AM.
