trying to build a rmt
  • Question : trying to build a rmt
    has anyone on here done a remote mount turbo before?i want to build one for my 92 z24 5speed. i want to run low boost right now since the motor is still very stock.im thinking around 5-7 psi range.does anyone know what would be a good turbo to use? im looking at some t3/t4's on ebay and they arnt too much to buy, same with the flange. but im looking at the trims ...and i have no clue what im looking at and what the mean.maybe next year or the year after that ill be doing a 3400 swap so i can fit in, maybe boost that as well.. but for right now i want boost.i like to research the heck out of stuff before i do it.im not running a cat right now and dont care about the sniffer ,i get my cars passed for about 60 bucks thru a friend.any help with this build would be very helpfull. please dont rag on my 3.1 ... i still kinda like it... its what made me fall in love with the 60* in the first place.
    thank you again
    8
    good idea
    25.00%
    2
    bad idea
    37.50%
    3
    might work
    37.50%
    3
    wont work
    0.00%
    0
    The poll is expired.
    Dont ever lift,unless its upside down or on fire.
    i think this time im going to have the flames painted on this car.im getting tired of my cars catching fire.maybe i need to start flipping them or lifting.
    Just put it in the engine bay. Do you really want 30 feet of oil lines running under your car? If you kick up a rock and it busts the line, game over for the motor. I would imagine there is a lot more thought to put into turbo sizing as well. Unless there is absolutely positively no way to put it in the engine bay, then dont go remote.
      I have built one of these for a 3100 and I could probably answer a fair amount of questions to get you going if you want to do it, as well as a few parts that I have left over. PM me with any certain questions you have and Ill gladly answer what I can for you
      BTW mine was built using alot of ebay parts and worked well on the stock small port 3100. Only had a few minor issues that I could have solved but went with underhood when I installed my 3400/3500 hybrid
      Best 1/4mile ET - 12.9
      Best 1/4mile MPH - 111
      1997 Ford Ranger Splash
      Daily Driver
        Theres a Cavi like yours that had a rear mount turbo too. It did dam well. The guy swaped to a 3*00 motor and ran 12s with it. He used a electric motor and a resivoir for the oil suppy for the turbo.
          He had a 3400 last I knew. His setup did damn good and as far as I know he is still running it. 89jy something on v6z24
          Daily Driver
            89jyturbo is his name, and yes thats the idea that i want to do with mine, but since he is running with a 3400 and i want to run mine with the 3.1 for now... i need to know what size turbo i should run so i dont blow the motor.im almost finished with my rebuild, all thats left is to rebuild the heads.. so the motor is going to be a fresh stocker and once its broken in right i want to boost it untill i can afford a complete 3400 or 3500 swap
