I have a 90 Grand prix with the 3.1. I'm doing a 5 speed swap the first weekend of febuary (getrag 284) and then I'm going to start tearing the motor apart probly end of febuary when i have all my parts together as i am still missing a few important items, anyways heres what i'm planning for a build.
My bottom end plans are bone stock rebuilt 3.1
For the top end I have the complete top end from a 95 3100, I know its not the best of the gen 3 top ends but it was cheap and I dont need custom length pushrods.
The crossover and everything turbo related is custom.
For management I'm using a TGP chip, 2 bar map sensor and I'm still undecided on injectors.
Now that you have an idea of what i'm dealing with i have a few questions.
Are the rings from a TGP diffrent from a NA 3.1? if so, I can use them in my 3.1 correct?
How much boost is the stock 3.1 bottom end good for?
What size injectors would be best for around 7 psi of boost? I know stock TGP's are 22lbs, would these be ok or should i go a little bigger?
and finnaly, what kind of numbers can i expect from this? I'm a little worried about my clutch, whats it good till?
Sorry so many questions all at once, I'm a bit of a noob to the 60* v6, i'm more of a quad 4 guy but thats a diffrent car, lol
thanks in advance
thanks in advance
