I have the T3/T4 Turbo, blow off valve, wastegate, intercooler, and piping to start off the project. Thats the easy part. I have a place
to work on the car during the project, thats a shop thats heated and has relatively nice tools from the plasma cutter to wire welders. A new job will provide the funds for the DHP Tuner and a laptop in order to use the program to tune the car for when i bump up the boost above the 5-5.9 PSI i'll start off with. The wastegate comes with the 5.9 psi bar, which as long as i don't go WOT i'll be fine on the stock tune. I can take it easy for a while as well as possibly find a friend of a shop to tune it with their tuners until i get my own.
The only problem i have right now is a few questions. When i go to hook up the BOV, it doesn't have precise instructions on where to exactly hook up the lines in order to let it function properly. Where do i route the tubing to in order for it to work?
The next question regards the wastegate, i haven't seen the directions yet, i just ordered it. Whats the best way to route the lines in order for it to open when the PSI is reached?
Next question, after all the lines in order for hte BOV and wastegate to function properly are placed in the system, where should the Mass Air Flow sensor be routed to ensure it getting the proper readings and what not? Before the turbo, or after the turbo on the pressure line after the intercooler right before the intake where its located now?
The next question i have is as far as the vacum lines that are on the intake that power the brakes and what not, do they need to be repositioned or have check valves fitted in them so that when the boost kicks in they don't get damaged? Do any senors, or other things need to be repositioned?
Other lines that i have in question are the oil lines for hte Turbo. Where should i route the pressure line from? Also, where should i locate the return line? Whats the easiest method on those? I'll be getting a boost gauge soon, as well as other gauges to monitor temps and other vitals as the project is under way. What kind of boost controller as far as manual ones are the best? I've seen quite a few varieties but i want one that is reliable and won't fail, and would this only be installed on the wastegate, or the BOV as well?
Thanks in advance for the help, and i'll post pictures as the project
progresses.
progresses.
