went to the track finally
  • went to the track finally
    went to the track today got one successful run in..
    i fell asleep at the light lol... the left lane took to long to stage haha... and traction owns me...
    mods are as listed...
    1996 beretta w/a 04 3400 3.5l top end, 42.5lb hr injectors, t3/t4 GARRETT .63ar 60 trim, front mount intercooler, greddy rs BOV, tial 38mm wastegate, 3" exhaust, high flow cat, 180* hypertech thermostat, fidanza flywheel, TG LSD, spec stage III clutch, ffp udp, walbro 255 lph, ffp dogbone, Ingall Camber Bolts, GM strut tower brace, z51 rear sway, fe3 front sway, new 92 5sp tranny, 92 subframes, poly control arm bushings, poly sway bar bracket bushings, poly endlinks, poly z51 bushings, carcustoms poly mount, kyb shocks and struts, eibach springs, battery relocated to trunk, TGP 2 bar map sensor, DHP Powrtuner, euro headlamps, euro tails, viper 791xv, Bfg drag radials, Goodridge G stop SS lines and more to come soon...
    Very impressive. Sounds like a fun ride!
    Matt
      how much boost?
        holy crap thats movin. good on ya!
        got zap-straps?
        89 Z24
        13.886 @ 96.16 mph
        street trim - slicks
          nice, although the 60' is killin ya. the old theory is 1 tenth at the 60' is 2 tenths at the top end. if you can get it off the line in the high 1.90 range you will be in the 12s.
          just for the record, running 15.4s i can pull 2.0 60' times on old hard drag radials.
            Nice, I can't wait to get some times.
              Me, either. Been too long already. Missed one race date this year, and it was the only one I had, so the new setup hasn't been tested yet.
                If i read correctly on bstuff, that was only 8lbs of boost.
                  yup yup
                    and a shitty tune with a good amount kr.... BOOOOOOOOOOOOO
                    im working on that
