I am wondering about my t3 hot side on my turbo. When I got it back the turbo shop told me that I did not need a gasket on the outlet of the turbo hot side. Now when I tighten the bolts I put  a light behind it and see the light come through. So would that me that the exhaust will leak out? I can find the gasket on e-bay for a t3 2.5" 4 bolt gasket Just 3". PLease let me know, I dont want to start the car up and it not be right.
T3 turbos have gasket?
	Tags: None
 I didn't use a gasket on mine, but my friend made me a 1/2" mild steel flange that he surfaced ground to be perfectly flat. The inlet definately needs a gasket, I use the stainless ones with a rolled edge (the kind that came with my turbo), and it works well.
 If you used an ebay flange that's kind of thin, I would recommend a gasket, and if it has a 3" hole in it for the downpipe, that should be OK.Last edited by ForcedFirebird; 07-09-2007, 11:56 PM.
 INlet I have for sure. I just know about the outlet. KNow where I can get one.
 You may want to do it. If the surfaces don't mate completely, that exhaust leak can melt underhood components and the gap can stress the bolts for the DP (possibly breaking or backing them out).
 325 whp 350 lb-ft
 Yep. The bolts I have had trouble with and the turbo is going to get drilled/taped for the next install. Not to mention, the holes seemed really shallow, so not many threads were catching and I ended up stripping one re-tightening. I would also suggest some lock washers. I used lock washers on the inlet side and they never came loose.Originally posted by timg View PostYou may want to do it. If the surfaces don't mate completely, that exhaust leak can melt underhood components and the gap can stress the bolts for the DP (possibly breaking or backing them out).
 Tim
 u dont have to have the gasket..you should be able to use high temp RTV on it..not sure for under hood but i did it on my RMT when i lost my gasket1994 Chevy Corsica. Parted out. Just a rotting shell now
 Best 1/4mile ET - 12.9
 Best 1/4mile MPH - 111
 1997 Ford Ranger Splash
 Daily Driver
