there are 6 bolts on the back of the compressor cover(cold side) u take those off and the cover will lift off exsposing the compressor wheel.u measure across the small side then the large part of the blades.(top/bottom)
to reaseemble just gently place the cover back on,as far as tq specs i always just snuged my bolts up with a reg wrench
its a 50 trim those bastards switch up all there shit again,
i would email them back again and tell them u did not recive the right turbo,and make them send u the right one. that shoulkd have had an 61mm inducer
even though its not the right one its still good for 475ish hp
(2.075*2.075)/(2.995*2.995)=(4.305625)/(8.970025)=48 trim
Not a very effieceint turbo, about the same as boosted's and mine.
hie measurements are slightly off i have one sitting here at home that i got.it is a 50 trim, infact i went as to even take off the compressor cover off the other one and tried to interchange them,they dont fit.im emailing the guy back as well
seems the new guys are using the reg xs power specs for there undersized turbos hoping to make some sales now that xs left ebay.
Kind of like our turbos were supposed to be 57 trim? I'll have to look at my pics to remember the exact measurements on mine, but it was closer to 47 or 48, not 57. (that's why I compare it to the 46).
not sure if this matters but i went ahead and checked the exhaust to and came up with 2.295 and 2.905 but with an odd number of blades it might be a little off. i'll be sending them some e-mails real soon...
should have a 2.5 inch out right? if so it should have a ptrim wheel stuffed into a t3 housing
