i didn't see anything related in the whole 5 or 6 threads in the boost section so i thought i'd ask: would there be any problem with this turbo on a 3100 and eventually a 3400:
T3/T4 Hybrid Turbocharger
0.50 A/R Cold Side
0.58 5-Bolt Standard Hot Side
3” Inlet Diameter
2” Outlet Diameter
0.50 Compressor Wheel Trim
0.50 A/R Compressor
0.63 A/R Turbine
57 Trim
Turbine Wheel:
Exducer : 2.48"
Mayor : 2.89"
Compressor Wheel:
Exducer : 2.07"
Mayor : 2.36"
25-35 PSI Peak Power Performance Output Capability
CNC Machined Flanges
or something like this:
T70 Turbocharger
Inlet (Exducer/Hot Side) T-3 Flange
0.84 Exducer A/R
0.70 Compressor A/R
Cooling/Lubrication Oil
Outlet (exducer/hot side) 3 " V-Band
Inlet (compressor/cold side) Ø 102mm (4")
Outlet (compressor/cold side) Ø 65mm (2.5")
Compressor major diameter Ø 84 mm
0.50 A/R Cold Side
3” Inlet Diameter
2” Outlet Diameter
0.50 A/R Compressor
0.63 A/R Turbine
57 Trim
Turbine Wheel:
Exducer : 2.48"
Mayor : 2.89"
Compressor Wheel:
Exducer : 2.07"
Mayor : 2.36"
T70 Turbocharger
0.84 Exducer A/R
0.70 Compressor A/R
