Turbo recomendations
  • Turbo recomendations
    I'm looking to replace my worn 60-1 .63a/r housing turbo with something else. It's on a 3400sfi with ls6 springs in a Fiero. I think I want to upgrade to an .82a/r exhaust housing. Possibly dropping to a 50trim for space reasons... I was also considering a holset hx35. I know the stock cummins ones come with a 12cm housing, which is close to a .82. I will be running between 10-14psi hoping for 350-400whp. Thanks for all your suggestions... later
    Justin W
    1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
    1990 Mitsu Eclipse GSX - parted out
    1991 Galant VR4 #108/2000 - Slammed sedan, built everything
    1995 Kawi Ninja zx7r
    1992 S10 4x4 - lowered/bagged, the dd
    2004 450R MX quad
    all the turbo guys out there... and no one can offer anything?
    2004 450R MX quad
      Its been less than 24hrs... not everyone visits the site multiple times a day. Give it a couple days...
        Why not have it rebuilt? You should be able to swap to a T04E or T04B compressor housing and the larger turbine housing at the same time. Problem solved.
        Tim
        325 whp 350 lb-ft
          precision SC6152E
            i don't know if it's worth the $$ for a new chra, and then the housings on top of it. unless you know something that I don't?!
            2004 450R MX quad
              It may be cheaper to buy a new one. You will need to call somebody like Precision Turbo to ask.
              Tim
              325 whp 350 lb-ft
                just go to http://cheapturbo.stores.yahoo.net/
                There you could get some turbo for good a price.
                for price on the Precision turbo's hmmm go to www.Arubaspeedshop.com
                They sell precision stuff
                  here is your Precision SC61
                  $550
                    cool, thanks guys... I just picked up a turbonetics 60trim. still a .63 a/r exhaust housing, so maybe I'll upgrade that.
                    2004 450R MX quad
