Here's the cleanest looking maps I've seen: www.innovativeturbo.com , maybe you can use them. Also,if you look at the T04B-H map enlarged you will see,t04b h-3 at the top.What's the 3 stand for ?
Hey Guys !
T04B H-3
The H-3 is a compressor spec. It's like the 60 trim on the T04E but for the B series.
Innovative isn't Garrett, so you might want to be careful with some of the maps. The older T04E and T04B's seem to be pretty generic between companies though.
325 whp 350 lb-ft
Turbonetics had a bunch of them. Turbonetics and Garrett were once related, but have since parted ways. The older maps should still be good though. I would base your maps on whatever you get from the place you're buying your parts from. That's one of the best ways to make sure that you get what you need.
ATP turbo also has a bunch of compressor maps.
325 whp 350 lb-ft
