Turbo
  • Turbo
    Hey everybody i was just wondering how much work needs to be done to run a turbo on my 3.1. I know a guy that put a turbo on the rear section of the exhaust but it took almost a full 30 secs to spool up. So somebody let me know how much work needs to be done cause it always sounds cool to hear the blow off valve work!!!!
    Jeff
    Check out www.v6z24.com a lot of guys there turbo their 3.1's or swap in a 3400 and turbo that. They burn chips to work with boost (and the extra fuel requirements of the 3400) and a 2bar map sensor.
    You'll need to be able to weld for one. There is lots of threads over there by several guys as the topic has been discusted many times and many build ups.
      Since you have a better mounting setup vs the old style L bodies, you could look into a TGP setup. Ebay has a few turbos listed from a TGP.
      Item number: 320085444158
      290087430938
        Thanx man, will i have to change out my pistons for some lower comp. ones?
        Jeff
          no, you don't have to... Just keep the boost levels down, a good sized intercooler, and a good tune, and you'll be ok.
          Justin W
          1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
          1990 Mitsu Eclipse GSX - parted out
          1991 Galant VR4 #108/2000 - Slammed sedan, built everything
          1995 Kawi Ninja zx7r
          1992 S10 4x4 - lowered/bagged, the dd
          2004 450R MX quad
