I have a a 88 Beretta GT, 5speed trans. I am in the process of installing a turbo as a spring project. I am wondering which type of optins there are out there to tune my car. I have a friend with a Z24 cavy that is tuning with megasqurit, but he had to take out the coil packs and convert to a fiero distributor, intake, and TB. I am not interested building a hybrid motor at this time. I would like to keep my factory coil packs and possibly harness. On the other hand i have seen that people are using RRFPR's or FMU's. I have not had good luck with these with my honda in the past and I ended up going to stand-alone in the end. I would just like to know all of my reasonably prices options.
Turbo 2.8 MPFI Tuning
Either the link to the store above or by his screen name : SappySE107-Brad-
Originally posted by ForcedFirebird View PostIf you are looking to tune yourself, Moates.net has the equipment you will need. What ECM do you have? I didn't see where you listed the year of your Berreta, but the last 3 numbers on your ECM probably will be 730 for a MAP system and 302 for a MAF.88 Beretta GT
2.8 5-Speed
Originally posted by TurboBeretta View PostI'm not sure at the moment what the stock ecu code is. but its a 88 Beretta GT. Is the tunerpro software any good? It sounds like a sister program to my turboedit i use on my CRX
ya my car def. has MAF I remember dealing with it when I was building the air intake for it. A guy on another thread told me to use the #1227727 16197128 ecm out of a pontiac tgp. Is this a plug and play ecm swap. I'm not sure if you have to change other things or not with the harness88 Beretta GT
2.8 5-Speed
Originally posted by TurboBeretta View Postya my car def. has MAF I remember dealing with it when I was building the air intake for it. A guy on another thread told me to use the #1227727 16197128 ecm out of a pontiac tgp. Is this a plug and play ecm swap. I'm not sure if you have to change other things or not with the harness
