1996 Grand Prix, 3100, 117k miles... new gaskets from the LIM up.
I'm trying to think of the cheapest, easiest way to add some power. A turbo seems like a good solution, running about 10psi with everything stock. But after all of my reading, I'm curious about a few things.
1, the turbo it's self. What inexpensive turbo (new or used) should I look at? I was hoping to find one with a built in wastegate, and one that didn't need oil lines, just coolant... much easier to hookup (could just hookup to where the TB coolant hoses go).
2, limiting pressure... I know the wastegate limits the overall pressure, but how do you set it to say 10psi? I don't quite understand how a boost controller works if there is a spring on the wastegate that makes it open at X pressure.
3, transmission. How long is the 4t60e going to hold up? How much work would it need to safely hold the power this will make?
4, exhaust. Could I just grab an extra crossover and rear exhaust mani, and have a flange welded to the crossover and the exit on the rear exhaust mini closed up?
5, room. Is there any way I can fit this in the engine bay without having to move the battery? Cheap/easy is the key here, and moving the battery costs for a new battery and the stuff to move it.
6, injectors. What could I use that would be a direct replacement? Stock pump should be enough for only 10psi...?
7, tune. Say I got a DHP tuner, everyone says you need a good tune. But what exactly do they mean? I mean you plug it in and stuff, start it for the first time... how do you tune without worrying about it popping from NOT being tuned? What exactly is "tuning", like what do you have to watch/stock/change/ and test.
