My best 60 was 1.89 I believe.
My rides at the track Turbo Camaro/ and GP L67
Yea the 60 foot really makes me happy. Although im tearing into the engine right now replacing the stock valve springs and retainers. Im using comp cam 981-12s for springs. I have a feeling that im seeing some sort of valve float at high rpm. Not the pop pop kind but just the lack of power at 4500 and up. Valve float from boost is weird as i thought it would be a missing condition but mabey there just never closing at higher rpms. Im still a newbe at all of this. The cam should be making power from 3500-5500 easy but seems as if its not and has been so since i first turboed it.BorgWarner S366 3.1/3100 Turbo Thirdgen
1/4 mile best 11.59@119mph
1/8 mile best 7.47@94.9Mph
If your boosted and running stock springs I would agree you are probably floating the valves... Stronger springs are a must with many aftermarket cams and NEEDED when boosting.
Ill be adding them on sunday if all goes well. Im attempting to do it with the heads on so that i dont have to tear them off. If my air compressor can keep up i should have them changed out pretty fast.
I do know i should have changed them out awhile ago. But i didnt know any better at the time. So hopefully theres no harm done to the cam, and the car will like the new springs.
Ill let you know how i like the 981s. They should be fine for a larger cam also. I plan to add a bigger dur. one this winter in the off season to up my power band a tad.BorgWarner S366 3.1/3100 Turbo Thirdgen
You went with non behive springs? You need different retainers correct?
Yup, i got the matching retainers that were required for them.
I got them installed yesterday. Went well. I just need to set the timing correct as im seeing 4 different marks at once on the damper when setting it. The digital 6 plus MSD box is shooting off multiple sparks at idle and my timing light doesnt like it...BorgWarner S366 3.1/3100 Turbo Thirdgen
Originally posted by 3400-95-Modified View PostIf your boosted and running stock springs I would agree you are probably floating the valves... Stronger springs are a must with many aftermarket cams and NEEDED when boosting.
I believe I will be replacing them for stronger down the road sooner then later.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
I've dialed back in the tune. Same 12.5 psi command. It definitly is using a little more fuel up top.
Going racing friday and saturday so well see if its really any faster or not. Hopefully I can still rip off those 1.7x's 60 foot times so I can run 12's.BorgWarner S366 3.1/3100 Turbo Thirdgen
