Wow that's impressive man! Definitel gives me something to think about for the future. I might be thinking further into the 3400/3500 swap but doing something like this with it. I don't think the stock 3.4 will take the boost for long and I really don't wanna pull it out again...yet... Really do like the headers and the intake setup. Just very cool man, have to say I'd rather have a 12sec V6 Camaro than a 10 or 11sec V8 one, not too many of them around.
incar video is hard ive tried it camera bounces around to much and makes for hell trying to read the quages
i see no reason to dyno the car now now that i have the wideband tunning this thing is so much easier,i was really going to the dyno just for the wideband since 100 bucks beat 350 bucks as far as price.
just for the hell of it i ran some numbers and come up with about 320rwhp which works out around 385hp at the motor,but this is still not tunned right
i should be able to push this closer to 350rwhp and 41x at the crank without turning up the boost with a lil more tunning
Um, people take video in car all the time, I doubt your car will bounce around any more than the in-car video I just wached, it was a 7 second pro-mod.
I'm not saying this to be a jerk, but you would probably be very dissapointed in real-world numbers. Those HP calculators are extremely inaccurate, Lance's car just dynoed 281hp/298tq and his car has a best of 12.486 @ 106.89mph (3800II in a 4th gen f bod). You run those numbers through your calculator and see if they hold true. Using simple math, I can tell you the calculator will come up with ~325hp or so using trap speed and ~345 using the ET.
Just like you calculated Loner's car using his trap and ET, saying your car makes more power, but if wasn't spending 2.6 seconds of that ET in the first 60', your HP calcs would change significantly. Just by getting more/less traction doesn't change your power output, but the calculator will say otherwise.
lol well i tried with a digicamera ziptied to the seatbelt loop on the side of the driver seat,it didnt work out well at all lmfao.
when i cage the car im going to fab up a real camera mount
u can only do the calcs on a clean run
another thing about dynos and highstall converters if u dont lock up the converter the numbers will always be low. gota find out if he did lock it up or not on his pull it takes more then 281rwhp to go into he 12's
#1 1989 RS - THE L98 AND LT1/LS1 KILLER
1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
#2 95 granprix 3100 all stock for now
ported heads and cam comming soon, megasquirt ems and turbo down the road
I've got 275 WHP and running 13 flat N/A.. soon to be 12's once I let down the slicks and get my 60' lower than a 1.9
Yeah. Most camera's have a threaded nut on the bottom for a tri-pod. You really need to rig somethin up better. They actually make a suction cup mount and it just screws to the bottom of the cam.
Right, Loner's never had a clean run because his first 300' is leaving rubber.
got the car tuned some more, also removing the front end suspension limiters
other then that i installed new rear brake shoes so we should be able to pull some 9psi instead of 5psi launches
so post up guys best guesses on what the cars gonna run
keep in mind every time ive had the car out we have droped .400-.500 of the et every run
first time out 14.50
second time 14.00
second outing 13.920 < due to pipes/coupler blowing part only got in the one partial run
last outing 13.4
final run last outing 13.008
i will go as far as saying a 12.0-12.1xx
lets hear what u guys think
