This is the second time this happend .. I was on the Mass Turnpike and I went to brake for a toll and I heard a grind ... so I pulled of to the side of the road .. looked for a bit and realized it was my passanger front brake caliper was flipped up hitting the rim .. Its the top bolt of the caliper. I know I tighten them good, and this is the only one with problem. Is it possible it could vibrate off .. twice? Would you recommend Thread Lockner? It is a part that comes off around 1-2x a year. Any ne else have this problem? Suggestions? Thanks
92 GP brake caliper BS
try wire brushing the bolt , seat AND spacer areas clean b4 you tighten them up.My Monte Carlo calls for 148lbs. Around 1.5 times lug nut torque. Be careful with Loc Tite.Not saying not to use it but seen a few beers cried in when the wrong color was used.2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
that happened to me 2x, thankfully it was the lower one so it allowed me to get home safely. i dunno why, i used loctite and torqued it to spec. i put on a new bracket w/ a new bolt and all fresh threads but havent driven the car probably 20 miles since it happened in june.
