Got a doozy of an electrical gremlin for you guys to help me figure out...
First, the AC fuse blew, leaving me without cold air... At this point, the voltage drops to about 12.3v. Replaced the fuse, battery voltage was back to normal. About a week later, it did it again. I verified its behavior by starting the car, reading 12.3v, shutting it down and replacing the fuse, restarting it, and finding that it indeed reads about 14.8v afterwards.
1. What could be causing the fuse to blow? The schematics in a haynes manual show the blower, AC clutch, and the relay for the cooling fan running off that fuse. And how is this affecting #2?
2. Here's the real doozie - after that fuse is blown, why in the shit does the battery voltage drop so much? (Voltage reads low both at the cluster, and at a 2-way VHF radio fed from the stereo wiring right off the battery.)
It acts almost like the alternator is charging the battery THROUGH the AC fuse... Electrically, I just don't understand how this could happen, but obviously something of the sort is indeed happening. I just need to figure out where to look for the problem.
