sticky radio buttons
  • sticky radio buttons
    So I just bought an 01 lumina a little while back. This car has only one cupholder, and Chevrolet had the foresight to place it directly in front of the radio. After roughly 5 years of occasional splashes from assorted sugary liquids, several of the radio buttons tend to stick. Is there any magic trick to clean these without damaging the radio? I'd rather not take it apart, and I doubt that spraying water on it is a good idea. Maybe rubbing alcohol? Some aerosol that I'm not aware of? Any ideas?
    i'd probly try water, if you go distilled water it probbly not be as prone to do damage. heck its got pop in it, how much can water hurt? if you got alchohol its probly the better choice, denatured would be best. it would at least be a cleanser and not just revive the syrup into pop form to dry back on and be back as square one. heck i just shot myself down didnt i?
    either way just make sure its off, or disconnected, so you dont hurt anything. water doesnt really hurt stuff unless there current to flow and short out. i drowned a radio shack R/C truck, the electronics were submerged and once it dried out it was fine.
      Pop... HA! I know a smut mag story when I read it!!!
      :P
        :P
        EW!
          It took me a second to figure out what he meant by "pop". Us simple folk just call it coke. Like posted above, unplug the radio and clean it but make sure you dry it soon.
          Kyle
          1992 Lumina Z34
          5 Speed
          Autozone civic intake
          Ultra White lights
          FFP Dogbone mount
          125k miles
          2.5 inch Magnaflow catback from Magnaflow cat
          60degreeV6.com Custom Chip
            You could use a plastic-safe contact cleaner, just spray it up. CRC makes one called CO contact cleaner.
