Rear Struts
  • Rear Struts
    Hi All,
    I need to replace my rear struts on my 93 3.4 Cuttlass convertible. I have yet to break out the book on it, but was wondering if any of you have any tips before I get started. Do I need to be aware of any tough situations I will run into. Since I am already in there, anything else that I should replace?
    Stan
    1994 White Cutlass Supreme Convertible 3.4 DOHC
    Add Ons: Overhead Display, Digital Dash, Trip Computer
    its a ton of fun...can't think of any tips other than breaker bar and air tools.
      24mm deep impact socket is the only tool I needed that I didn't have. Might wanna look into that. Its a pretty easy job altogether.
        Look into getting the rear struts that do NOT have the elongated lower knuckle bolt hole that allows movement/alignment. New Monroes have them this way. Just install it and it stays in one place and you won't need to guestimate a position or get an alignment (As long as you dont have accident damage)
        Also now is a good time to get new upper mounts if yours have any rust, also get the rear jounce bumper/shield kit to prolong the strut's useful life.
        Brian
        3400 SFI V6, 4T60e
          KYB GR2s have the elongated hole. It makes for a fun trial-and-error process.
            I'll be doing that over the holiday weekend. I haven't bought any of it yet. Are you saying get the Monroe Struts or not to? Any name brand suggestions for struts, upper mounts, bushings, etc?
            Thanks,
            Dennis
            Stan
              New Monroes are easier to install cause they don't have the elongated hole, but even if it did, it isnt much harder
              Brian
              3400 SFI V6, 4T60e
