I want to hard wire my radar detector, but run it off of a toggle switch. Is this really as easy as just cutting off the cig. plug, stripping the wires, and wiring it up?
Hard wiring radar detector
The hardest part will be figuring out which is hot and which is ground. It you wire it backwards, then there is a good chance you'll fry the unit.-Brad-
i wired mine into a key on power source so it automaticaly comes on when i start the car, though i don't use it anymore since cops around here use guns no detector will help find.The difference between an individual terrorist and a government in some cases may be simply that the former has a bomb but doesn\'t have an air force.
That's what you'd think (wire with the red stripe), but I have come across a few things in my time where the red striped wire was actually the ground. Not sure if it was just a goof from the factory, or was done on purpose though...-Brad-
You might fry a fuse doing this, but better then the radar detector...
Just run a wire to ground somewhere on the car and touch the non-red striped wire. If it doesn't blow then you got your ground wire. If you want to make absolutely sure, put the red striped wire on your remote ground wire and if it blows the fuse then you got your positive
NJ sucks for radar detctors
Cops around here use what its called stand by....actually the unit is off till they see u approcing then they do wat its a called a flash..where the unit will gun your cars speed by a push of a button...then shut off..so ur radar/laser has no time to warn you. My radar sits im on the shelf at home as a dust collector...
Also make sure your Radar is 12volt unit , mine only uses 6.5 and have a fuse in the end of the peice you plug into the cigerrete lighter so it dont fry.
good luck1996 Dodge Ram 5.9/4x4
1992 Grand Prix GTP LQ1/4t60-E
1986 Monte Carlo SS 355-3-71SC /200r4
Re: NJ sucks for radar detctors
Originally posted by montessgtpCops around here use what its called stand by....actually the unit is off till they see u approcing then they do wat its a called a flash..where the unit will gun your cars speed by a push of a button...then shut off..so ur radar/laser has no time to warn you. My radar sits im on the shelf at home as a dust collector...
good luckBrian
3400 SFI V6, 4T60e
Originally posted by RhedalertOriginally posted by montessgtpCops around here use what its called stand by....actually the unit is off till they see u approcing then they do wat its a called a flash..where the unit will gun your cars speed by a push of a button...then shut off..so ur radar/laser has no time to warn you. My radar sits im on the shelf at home as a dust collector...
good luck
