Im not sure what to focus on first but I have been told now that the same company that makes the throttlebodies can also make molds for bushings and motor mounts and whatever else. I was thinking about the W body lateral arms and bushings to swap out the rubber pieces in the GMPP trailing arms. I know the 3x00 swap into a J body needs a custom mount as well so if anyone has one or the dimensions needed, I can have those made. Mostly its the demand for these parts that will determine what gets made and what doesn't, so if you have any ideas, im open to suggestions.
Probably wont work on any underdrive pullies and dogbones as FFP has those covered, unless we can make an UDP with the torsion dampener ring in there. Liability/warranty issues though may make that not happen but I wanna check into it anyway since I know some people won't replace theirs without that piece on the pulley.
