Originally posted by The_Raven
		There's a few problems with putting drag radials on.
1) Strictly in terms of streetability, you would have to flare out the fenderwells, since 215 series tires are more-or-less in line with the body. Unless it's not illegal where you live.
2) When you drop the clutch at 4000rpm, something has to give. Generally that's the tires, clutch, or combination of both. With a high-horse motor, and a solid clutch, something after the pressure plate has to give. With sticky radials, you will destroy the transmision or one of the axles. I've seen pics of both; The trans case splits open and shits out the differential, or the axles shear off at the tripods.
So, I stand by my statement. The car will NOT survive long at 400hp unless you make concessions for a bit of "give" in the driveline, like not-so-hardcore tires.
