should have used two 3100 (or 3400's) to help keep the weight down!
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
he cam to the yearly MyMonte meet, regaurdless of the engines used I was quite impressed with the setup myself, alot of work and not to shabby, the entire car including roll cage came in at $2000 granted the guy is an ASE master tech and his co-hort is a pretty good wrench himself.
yeah it was a horribly hot day and everyone was running like ass, that was thier first time at the track as well, i would say the car does better than that. I think for them its not so much the speed as the uniqueness of the project.
1995 Monte Carlo LS
3400 SFI 60v6
Just think if that had twin 3.4DOHC engines. Did they just put the front chassis from the other olds on the rear of that one and then cover it up with the body? That is still freakin awesome. It has got to sound weird.
1992 Lumina Z34
5 Speed
Autozone civic intake
Ultra White lights
FFP Dogbone mount
125k miles
2.5 inch Magnaflow catback from Magnaflow cat
60degreeV6.com Custom Chip
its a custom rear cradle IIRC. both engines can start and run independantly of the other. and you can drive with either or both. 1 fuel cell, 1 massive fuel pump speced for pro-street applications.
1995 Monte Carlo LS
3400 SFI 60v6
