I can't wait for the GXP to come out.
Yea XLR are only V8.
Engine
Type: 2004 Northstar 4.6L V-8 VVT (variable valve timing)
Displacement (cu. in. / cc): 279 / 4565
Bore & stroke (in. / mm): 3.66 x 3.31 / 93 x 84
Block material: cast aluminum
Cylinder head material: cast aluminum
Crankshaft material: forged steel
Valvetrain: DOHC, 4 valves per cylinder, four-cam continuously variable valve timing
Ignition system: coil-on-plug ignition, with extended-life dual platinum-tipped spark plugs
Fuel system: sequential electronic fuel injection
Compression ratio: 10.5:1
Horsepower
(hp / kw @ rpm): 320 / 239 @ 6400
Torque (lb-ft / Nm @ rpm): 310 / 420 @ 4400
Recommended fuel: unleaded premium
Max. engine speed (rpm): 6700
Estimated fuel economy
(mpg city / hwy / combined) 17 / 25 / 21 (est.)1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by SappySE107i threw away the brochure from the chicago car show, but I know I saw the 3.6 DOHC listed as an engine choice with it at one time.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
