Tire Size
  • Tire Size
    I bought some 17" x 7.5" rims for my 97 grand am.. i had originally planned on putting 225 tires on it..but... could i go with a wider tire on that rim? perhaps a 235 or a 245 even? or will i run into wheel well clearance issues? Ive looked around on a few sites and ive gotten mixed answers, tire rack said 225 is the widest i could put on that rim, and bridgestone said i could use a 245 tire. But i would really like to know if a 245 would fit without rubbing the front wheel wells. thanks guys
    RE: Tire Size
    I have 215/17s on my Beretta and they rub the wheel wells on some turns, but I am also lowered ~1", so that may make a difference.
      RE: Tire Size
      Im running 235/55s on 16x6.5s with no rubbing or clearance issues, plus my speedo isnt affected by more than 1%.
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
        you can fit 245's on 6.5" wheels, but im not sure if they will rub on a grand am.
        91 GTP HM-284 GONE
        96 Special Edition LQ1/4T60E GONE
        98 Spawn of Satan (L67 Regal)
        87 V10 SM-465/Mild 350
        06 Cobalt SS/SC GONE
          yeah my gtp had 245/50z/r16's on the stock 6.5 rims.
          Jake
            I say go with 225 .. theres no need for 245s on a Grand Am ..
            New member of 200,000 mile club as of May 16, 2005
              Jake
              Those crosslace stock rims in your cardomain site .. I thought those were 16x8 rims
                Jake
                If they game from a TGP they are 16x8. If they are from a GTP, then theyre probably 16x6.5
                Robby Whitesell
                2006 Pontiac G6 GT
                  well there factory on the car like that, i didnt take them from a tgp, i could have sworn they were 6.5's but maybe they are 6.8's now you got me thinking. ill check tommorow and post it.
                  Jake
                    Thats not completely true...To run a 245 or 235 on a GA he would have to run a 40 series. Most 40 series tires in that width are designed to run on an 8" wheel. You could probably squeeze them on, but your not going to get the maximum performance from the width of that tire. Not to mention if something were to happen where you needed to use the manufactures warranty (If one is provided)...the manufacture will tell you your SOL because you didn't go by their recommendations.
                    Best bet for that wheel would be a 225/45...
                    67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
                      I don't think I've heard of anyone putting 245's on a Grand Am. with 17x7.5 you should be able to fit 235/40-17 (just a guess at the ratio). What is the stock tire size? Isn't it 225/50-16... or at least that is the optional size right? If so you should be able to fit 235/40-17's without rubbing. And those will fit on a 17x7.5" wheel. If in doubt you can always check www.tirerack.com they usually have the rim width specs for each tire size.
                      --Rob
