w-body bose systems
  • w-body bose systems
    does anybody know the specifications of the stock bose systems in the early 90's w-body cars. like watts put out and ohms that the amp runs at.
    thanks,
    chad
    91-z34, auto
    94-chevy 1500
    RE: w-body bose systems
    OK, I see nobody has responded, so, I will. Truly I don't know, plus they probably don't advertise it either. So, my guess is you won't find out. But Honestly, the cheapest peice of shit amp you can buy is probably better. That also goes for the speakers too. I have used amps rated at 25 watts per channel that blow away any bose system. Plus the speakers are of poor quality construction and are nothing to get excited about. If you are really want to know the amp rating. If you can find the amps fuse rating, then figure about 100 watts MAX per 10 amps of fuse.
    Lyle
      thanks for the response man, yeah i notices the whole thing is a pile, basically the reason for the post was to see what i was startin with. now knowing that i prolly wont find out ill most likely start from scratch.
      thanks,
      chad
      91-z34, auto
      94-chevy 1500
