By the way, could someone tell me what is special about the FE3 as apposed to other Cutlasses???
FE3 Question
i've got an 87 or 88 buick that has the FE3 suspension, TH440, and the H.O. 3800 series 1. kick ass car but i want rid of it.1996 Chevrolet Monte Carlo LS/SS 3100 SFI
T.B. coolant bypass - RedZ intake - MAG-XTS wires w/ AC Delco Platinum plugs - DHP PCM - 3400 SFI TB - GM front strut tower brace - FFP UD pulley - OD alt pulley - Viper 791XV Protection
The FE3 gives you a rear sway bar whereas FE1 you get nothing. Front bar is 30mm solid, front springs are a hair lower, stiffer. Rear has a more solid "auxiliary" spring vs the figure-8-shaped FE1. That about covers it.Brian
3400 SFI V6, 4T60e
Originally posted by robby1870Want to note that later FE1 cars, e.g. my old 92 GP had a smaller (12mm) rear sway bar, as opposed to the larger FE3 (14mm) rear sway barBrian
3400 SFI V6, 4T60e
