Lifters
  • #16
    That I am afraid to do.
    Now let's assume your lifters can't handle 8,000rpm. What will happen if I install them, and use them, and still try to run the motor to 8,000? I am just nieve about hwta it will do. Will it stop revving? Float the valves? Thanks, I think it will be neat to see how the 3.4 makes power with an aftermarket intake above 7k.
    • #17
      Well they have a better chance of doing it than stockers. They will just collapse the valve, meaning a lot less valve lift. They aren't going to blow up or anything. You should really go solid lifter though if you want the best setup for high RPM. 8k might be ok, 9k is very doubtful.
      • #18
        I am going to be sticking to 8,000, nothing past that. I wish i could get a rev limter at like 8100, but I will have to do it by a tach.
