You should get some high temp flat black spray paint and paint your coolant bottle. That mustard yellow color is FUGLY! Otherwise, good job on the bling bling.
Basically, you just use a sanding block starting with real coarse grit sandpaper. I started with 80 and worked my way up to 180, 220, 320, 1500, and finally 2000. Be careful when sanding the 3.1 MPFI lettering as the sandpaper will tend to snag there if you don't keep the sanding block level. Once you get over 300 grit, switch to wet-dry paper you can wet-sand. Makes it much easier.
After you're done, using a rubbing compound or a polish designed for bare metal will really bring out the shine (a protective coating it necessary to keep the metal from tarnishing or oxidizing).
This takes a LOT of sanding to get that mirror finish with no fine scratches (took me about 6-7 hrs total). Some people say use a power sander or buffer, but I think you always get nicer results on a small surface like this by doing it by hand. Also, you'll have to remove the valve cover to polish that.
\'90 Cutlass Supreme SL coupe - 3.1L LH0 V6/HM 4T60 -- every factory option Flowmaster 40 - no cat // K&N FilterCharger // KYB GR-2\'s // Stant 180º SuperStat
